Alright, so I just got my new cheapo box in the mail so I can get started on my "dry run" in replacing the CRT with a touch screen portable media player.
I plan to do this with a box that actually has some decent components but I wanted to get started with something i could afford to destroy if that happens.
I have just gotten the disassembly done and replaced the belts to get the tape working again. Found the problem with the right speaker not functioning and resolved that as well. (just a bad lead)
Here are some pictures of me disassembling the box and removing the CRT.
Next comes the fun part; actually removing some of the plastic bits on the inside to make room for my new 5.2" widescreen touchscreen portable media player.
I have chosen the one I will put in there and just need to purchase it. The wifey says I cant buy it till after the honeymoon next week so when I get back I'll finish up and install the new one and post up part two!
Enjoy
Enjoy
