Have you ever felt that the sponge in most battery compartments is not meant to last due to is delicate or fragile composition? I did but, now even more so, since finding deteriorated, crumbling foam/sponge was way past it's usefulness.
Here's the custom fix I came up with to replace sponge/foam that had turned to dust:
Materials: vinyl (type) fabric of choice and an offcut of durable artificial foam. Carefully check the combined thickness is of an appropriate size by 'dry testing' in the battery compartment.
Cut materials to size, affix double sided adhesive tape to foam/sponge and stick to the vinyl cover (to be!).
Apply a second strip of double sided adhesive tape the to top exposed face of the foam/sponge.
Fold over the ends followed by the sides and press firmly to ensure a good bond.
Using a third strip of double sided adhesive tape, fix the padding joint side down and, again, press firmly to ensure a good and lasting bond then step back and admire your work!
Next Instructional Guides:
1: How To Weave A Pretty Pink Tuning String!
2: How To Crochet Woolly Speaker Grills (to keep the cold out)!
3: How To Use A Knitting Needle As An Antenna!
4: How To Paint-By-Numbers Your Very Own Tuning Display Using Only A 4" Brush, Eye Liner And A Lipstick!
