Crown SZ 5100 SL EQ not working
Sel The Don
277
28
28
44
Bursa, Turkey
Hello all,
Picked up my second 5100SL today (first one ended up smashed to bits after an unfortunate mishap).
Everthing works on this unit except for the EQ, I've took it apart, reflowed all the solder connections and still no joy. The weird thing is the sound is pretty good.
It looks as though the signal runs through the EQ before the output (when I desoldered the EQ off the main board there was no sound) so the signal path is good. EQ sliders are all giving me resistance. could it be bad caps that could cause it not to work or am I barking up the wrong tree?
Also, the was a green wire soldered from one part of the main board to another but it fell off just looking at it and can't figure out where it went. Does this have anything to do with it?
Cheers in advance
zzmbie
4
Switzerland
Hello,
i have the same Box.
Just move all EQ Sliders severall times up and down >25.
My Crown was new and the EQ dont work like yours.
Just proof it!
Cheers zzmbie
IVH
58
Did you detox all sliders and moved them at least 20 times?
5,762
275
Give a Deoxit treatment and move ~ 25 to 40 times!
Without a cleaner/lube like Deoxit moving several times is a crude way of making it work.
You have no guarantee it is going to work again.
:yes:
