Crown CSC-850 belt sizes please
docs
2,558
381
United Kingdom
As the topic says, in order to restore this one I need to find out the belt sizes. Unfortunately the ones in there are not measurable as they are elastic bands and do not have the correct normal unstretched size. :sad:
Any help appreicated,
89
I believe I had seen a forum on s2g about tying a piece of string around the pulleys and then measuring that way with a subtraction of 5-10% of total length. or you can buy the kit of square belts and test to see the best one :-D Hope this helps ;-)
