@Max:
Just to clarify, I have not diagnosed your box. My contribution previously was only to follow up on Bill's post about my post in the other forum, regarding a different C100 and my comments regarding the C100 amps being failure prone and my suggestion that if replacing, to find OEM chips. That's it.
Before you replace your amps, you really should be investigating whether or not the amps are at issue. Keep in mind that your amps are separate for left and right channel. So unless both amps failed at the same time (less likelihood), then whatever the issue is must be common to both channels. There are only so many things that can be common to both channels and a single weak solder joint or a single bad capacitor is unlikely to be the culprit since unless it involves the power rail or something similar, such failures usually involve only 1 channel if it's in the audio stream. This involves checking to make sure your amps have power, making sure your tuner has power and you can do that by checking the appropriate places with voltmeter.
You should also check your line-in and line-outs because (1) your Cassette is not working and (2) you did not check your line-in. That's already 2/3 of the source generators leaving only the tuner. Well, if your tuner is dead, and you don't confirm whether either of those other two sources are "live", then the dead amp conclusion is faulty. Also, you need to verify whether line-outs are working because that will at least tell us whether the line-amps are working. If yes, then we can move on to test the preamps.
Your power amps -- remember to check pin 2 or pin 5 of each amp with a signal tracer. A signal received at either of those two pins suggests that the amp is not amplifying the signal. However, if either of those pins, and I think pin 2 is the primary one, does not receive a signal, then the faulty amp diagnoses would be premature since the amp can not reproduce or amplify an empty signal.
Finally, you say the alarm works perfectly. Well that sucks. I mean not really, but the alarm really is an oscillator that sends a signal to the amp, and if the amp is blasting out a loud sound from both speakers -- that suggests to me that the amps may indeed be working OK since it's apparent that it has no trouble reproducing and amplifying an audio signal.
