Boombox Repair/Restoration Kit
monkeysee
20
UK
What would be essential Items for a newbie just starting out ?
What is the best way to remove 20 years of dirt,dust,nicotine etc without damaging the finish?
10,900
130
Well, here's my list of usual items. Maybe I'll round everything up and take a pic:
* Various assortment of flat-head and Phillips screwdrivers including miniature sizes
* Soldering gun
* Needle-nose pliers
* Tweezers
* Small telescoping magnet
* Q-tips / cotton swabs
* Isopropyl alcohol
* Meguiars Plast-X polish
* Endust wipes for electronics
* Orange Glo
* DeOxit
* TDK electronic demagnetizing cassette
* R/C fuel tubing
* Assortment of dental-type picks
* Multimeter
* Test tape
* X-acto knife (or similar)
* 2-inch paint brush
For basic cleaning, just go with a mild detergent and water. For tough stains, grime, grease, and dirt, Orange Glo works wonders!! Just don't use too much of it. ;-)
Master Z
1,223
Toledo, OH!
Nice list FD, other things I use include;
- A multimeter
- test tape
- RCA cords to test in/out puts
- Paper clips (I use them to pull dents out of grills/ and to clean real tight places. works well.)
- A working boombox so you can listen to while you work!
- Beer or liquor for the real tough to figure out problems.
- A digital camera to document and post up on Boomboxery!
Peace.
Paul Z. :cool:
10,900
130
- A multimeter
- test tape
DOH! How could I forget those?! :-O I've updated my list. Thanks MZ. :-)
10,900
130
Let me go ahead and post Vladi's response to this thread:
"Single malt scotch - I won't open another boombox without it."
:lol: :beer2:
you can also dismantle the box and wash all non electronic parts in the bath tub ,then when it's dry put it all back together ,you can dust the speakers and the guts while its apart.
stynger007
275
72
28
59
The Great White North Canada
Use WD-40 to remove sticker glue ( I hate stickers on boxes!) First remove sticker by hand best you can, next spray on wd 40 slowly, let it penetrate, then wipe away glue! Recommend trying it on an unconspicuous area like the bottom in case the finish decides to come off with it.. ;-)
10,900
130
If WD-40 proves too strong for the finish of the box, you can also try Goo Gone's Sticker Lifter. Although it might make sense to test it also. ;-)
spatterlight
The other day, I spent two hours pulling a bunch of twenty-year-old Toronto Blue Jays stickers off an old Panasonic RX 5080. I found that different glue residues needed different cleaning liquids to really come off easy, but the winner for me was plain white vinegar. Plus my thumbnail beats the pants off a sink scrubby for glue lifting action.
mindstate612
62
45
Minneapolis
I love the list fellas, I just started taking apart some of the projects I have... I find it myself very content and entertained detailing these old boxes that have been collecting dust for many years. :w00t: :w00t: I've been learning the small tricks of the trades through making a few mistakes here and there. Now if I could just figure out the smartest way to remove the grills so I can clean and repaint them.
89
On your SCR8 you need to bend all tabs and cut glue with razor, then evenly push grill out...Good luck ;-)
10,669
168
40
WI
Don't forget things to fix damaged boomboxes! Acrylic Cement is the best and everyone should have it "just in case" ;-) :yes: :thumbsup:
mindstate612
62
45
Minneapolis
what brand makes the best Acrylic Cement? :hmmm:
bobdog
16
Narrowboat on the River Soar U.K.
.....As you are also UK based...check out maplins/ rs componants or cpc for Servisol products....
Great switch cleaner and they do a foam cleaner you can just spray all over and work in with an old tooth brush....works a treat!
