JVC Floyd said:for me its the pc 55,it has power to spare and sounds good with sony apm speakers.
redbenjoe said:my vote is the m70 -
PLENTY of power --
good deck and radio
hard to explain exactly...![]()
but as soon as you guys hook some BIG bad speakers
to it -
then you will KNOW !!!
...what type of speaker connectors do you use to connect to the external speaker plug?? All my speakers have dual (positive/negative) exposed wires...redbenjoe said:my vote is the m70 -
PLENTY of power --
good deck and radio
to it -
oldskool69 said:Well, though a great topic...the question really is...
"What are the best speakers to run externally from a boombox?"
The key is the efficiency of the speakers themselves. If you would like I can get into the specifics.![]()
