Belt fitting
sbsshadow
61
Morning all
So my packet of general belts arrived yesterday and im going to try to fit them to my Watson RR-5600
Any advice or tips please ?
Thank you
Stephen
10,900
131
When you don't know the specifications of the original, you can use white string to measure the needed belt length. Then find a belt as close to that measurement as possible.
sbsshadow
61
Thank you both, luckily one of the decks still have the old belt on , so I will be removing that and judging the size
Northerner
5,325
256
North West UK
Always handy as it shows you the right belt path and you just put on a new one a bit smaller...as they tend to stretch with age
