Aiwa cs880 Play cam gear
2,516
346
The service manual lists it as part number 82-585-244-01.
A quick search shows it's also used in the AD-WX110 and AD-F220.
The WX110 is a double deck, so you'd have two gears, in case one is worn.
There's a bunch on ebay, with one starting bidding at $1.
Good luck
Funkateer38
142
13
Hello,
Does anyone have a source for tape deck gears for a CS-880?
Thanks,
Paul
Hello,
i just rebelt my AIWA CS-800. After service, the player did not works properly. I thought that it was the cam gear problem. But after reflexion, it was a bad position of t-spring auto eject.
