No. Something is not right with the measurements. If you are saying that the voltage going to the PS board from the transformer is 13v a/c, you can't get to 32v DC from there unless there is a step up transformer or some form of DC to DC converter. The only thing that the PS board does is (1) rectify the A/C to DC and (2) perform the switching from A/C-in to DC-in to BAT-in and (3) Filter the output by means of the large filter capacity. Failure of any of those features does not increase the voltage. However, if the input voltage switching is performed on the board and there is something screwed up there, such as a short, or miswired connections, then I could see how that might be a possibility. I presume that the yellow/white/black wires go the the power transformer? Then those might be the transformer primaries and if you truly are getting 32volts, there is a very good chance that significant component failures exist on the main PCB. Transistors, resistors, diodes, etc can tolerate fairly high voltages but not current. Increasing the voltage by 300% will increase the current consumed by 300% as well, if impedance remains the same. Also, capacitors can get damaged/explode if exposed to voltages outside the range of their rating. The biggest problem will be the IC's such as the power amp modules. Most have a fairly small operational voltage limit and I would guess that your amp is rated at 15-16 volts max.
