Sharp GF575 left side audio is quiet
Jud55
I purchase this about 6 years ago and had it stored in the loft and im pretty sure it worked fine before putting it away
I came across this thread here
Mine is pretty much the same except there is volume to a small degree, im no expert in any type of electronics , would cleaning the slider be a good place to start if so what do i need to buy to do it, its on all the functions as both tapes do it and so does the radio.
Thanks
Lots of connections pass through that record/playback switch. Radio might work then tape, line in and other functions might not. So, it is likely that switch dirty and oxidized like Superduper mentioned.
Jud55
Got ya, sorry for the dumb question but what part are you referring to by "record/playback switch" and what would i need to clean it, or is it a case of swapping it?
Yes, it is a long bar shaped switch, typically on the main circuit board. Clean by orienting the boombox so that the switch is pointed North/South. Spray deoxidizing electronics cleaner into the top end while actuating the switch to allow the solvent to work its way down and through the switch. The switch is spring loaded and may need to be moved scores (50x or more) for thorough cleaning. Blot up excess solvent when done and allow to dry before powering up.
Reactions: Jud55
Jud55
Just waiting on some cleaner spray to arrive, i will update once it does thanks
Jud55
Success, so glad you guys are around, it saved me £125 that i was quoted to get it repaired.
Now its time to install a BlueTooth unit, I have already worked out how to fix it in place and as it goes into pairing mode when powered on that saves fitting a pairing button.
Reactions: Tinman
Jud55
Ok so I worked out how to fit BT to the unit, i do have a buzz that is mentioned in the video, a quick google gave me a few ideas, I think i need a b0505s Isolated Dc-Dc Convertor as im pulling power from the mainboard, it initially was running from a USB power bank and i had no buzz so im guessing thats the reason.
Any suggestions are welcome as these parts are designed for breadboard application but i would prefer something that i can put inline (like the buck convertor i used).
goodman
Yes, I guess this b0505s Isolated Dc-Dc Convertor will solve the problem.
If you are going to use this Sharp at home connected to the AC,
you can try to power the BT module with a regular phone charger.
The AC of the charger is connected with cables to the AC input of the transformer.
The output of the charger to the BT module.
I use this method in my modded Sanyo C30 here:
On the left is the MP3 module, in the middle is the phone charger connected to the AC of the main power supply, on the right.
I even put a switch to turn it on when I use it.
Sanyo C30 - 08
by ivosn
