Testing the New AI7012 Retro Styled Boombox
BoomBoxStash
I wrote a basic review of this new Aiwa boombox. Herein, I will detail results of my evaluation.
Speakers:
The woofers are 'true' woofers in both appearance and function. Large excursion (possibly treated) paper cones and foam-rolled cone suspensions. Decent magnet (maybe 8-10 oz). Measured free air-resonance (removed from enclosure), 62 Hz. Very good! Woofer output seems to roll-off. No added distortion to the treble output.
The tweeters are true 0.75" soft textile domes mounted to a slight wave-guide type flange.. Small ceramic magnets work well. Flat, even sound.
2-way bass reflex, with a calculated enclosure resonance of about 55 Hz. Very nice. Port is relatively large in proportion to the woofer, limiting air noises. A 2" flared exit further reduces chuffing. A simple 4.7 uf cap nominally crosses over around 8 Khz. Works quite well, imo.
Each speaker mounted in a fully enclosed sub-enclosure, very well reinforced.
Amplifier:
The amp chip is a CD7379CZ, which seems to be a knock-off of the TDA7379.
Aiwa rates this boombox at 20 w/ch Peak.
Other versions of this same model (all made by Leotech), state output at a more realistic 10 w/ch RMS.
The chip's data sheet indicates output at around 13 w/ch with a 12 volt power supply. I could not attain that high an output.
I measured:
10.6 w, one channel driven, 1 Khz @ 10.3% THD.
8.5 w, one channel driven, 1 Khz @ 0.996% THD.
8 w, one channel driven, 65 Hz to 20 Khz @ less than 0.35% THD. Very nice.
Overall frequency response: 45 Hz to 20 Khz within -3 dB.
Power Bandwidth: 65 Hz to 20 Khz within +/- 1 dB. Very good.
S/N Ratio > 95 dB. Excellent.
Tone Controls: Bass: 6 steps @ +2 dB per step. Turnover is 1 Khz. Center frequency is 100 Hz.
Treble: 6 steps @ +2 dB per step. Turnover is 1 Khz. Center frequency is 10 Khz. (typical settings. I prefer 50 Hz and 20 Khz, respectively).
X-Bass: about +7 dB at 100 Hz. (not a Loudness control. No treble affect).
The amp chip is mounted to a large aluminum heat sink. Very good.
The internal wiring from amp to speakers use actual quick-connect ends rather than soldering. I like that. The end clips even have rubber slip-on covers, preventing shorting issues.) Very nice.
CD Player:
Frequency Response: 20 Hz to 20 Khz with a -9 dB roll-off in the low end.
(However, this could be due to measuring the CD output via the headphones-jack, which may be subject to the same bass roll-off as the amplifier)
The CD response from around 100 Hz to 20 Khz is extremely flat. Imo, this indicates the CD player is better than the measurements suggest. Response above 100 Hz actually rivals my LG Bluray home component CD/DVD Player.
S/N Ratio is around 88 dB. Very good.
THD @ 1 Khz is under 0.1%. Also, very good. Matches my LG Bluray component CD/DVD player.
Very quiet mechanism. Very good.
Programmable playback. Nice.
Tape Deck:
Tape deck is so-so. I cleaned the tape-head prior to testing. Operating the tape deck flooded my mind with good memories of tape recording long ago. However, it also made me realize some possible issues with this deck. I will point out all good and bad, as follows:
Decent looking Record/Playback Head and separate Erase Head. Good. (Some cheap decks use an inferior permanent magnet in place of the Erase Head.)
I recorded a 1 Khz sine wave. I noticed warbling (wow/flutter) upon playback. Not so good.
Frequency Response: Around 80 Hz to 12.5 Khz within +/- 10 dB or so. Not bad.
I used a new Maxell UR tape. This tape states "for general purpose recording". So, it could affect the outcome. Back in the day, I bought TDK or Maxell, as they were the best for high fidelity purposes. Back then, Aiwa may have recommended Sony brand, as Sony was their parent company. It was believed that using the brand employed by the manufacturer to set the deck's bias and response yielded the best results.
S/N Ratio: around 46 dB. Actually, pretty typical for a Normal Bias without noise reduction. Fair.
However, noise was very evident below 1 Khz, making some measurements very difficult. Overall recording quality is not too good, compared to the oldies but goodies boomboxes.
THD measured over 3%. If I recall correctly, even the good decks back in the day had higher levels of THD. But I do not remember for certain.
This deck lacks some things which I must be honest and disclose:
No Full Auto-Stop function. Not good. When winding a tape, you must stop the tape at the end. Otherwise, risking stretching the tape. You don't want to do that. You cannot see the 'stretch', but you will hear a 'thumping' sound near the stretched portion. Your recordings will be ruined. Stretching a tape is akin to scratching a vinyl record.
No tape counter. Would be nice to have.
Tape deck door is not removable. Many of the great boomboxes, as well as many component tape decks of the 80's, featured removable deck doors. This made cleaning and demagnetizing the Heads and Capstans much easier. Too bad.
No access hole to the Tape Head Azimuth Screw. This makes it impossible to easily adjust the Head Alignment. Disappointing.
Tape Deck keys feel solid. That's good.
Recordings made with this deck will not rival the old school boomboxes. Maybe the Lasonics. The Lasonics, especially those introduced in the latter 80's, were not hifi either.
But, playing back older tapes made on good machines shouldn't be quite as bad. Just expect some noise in the background.
Many people mention that no noise reduction is available. This is partly due to Dolby Laboratories no longer allowing their patented products to be used. I imagine some day, those patents will expire and possibly allow manufacturers to include noise reduction. Other noise reduction circuits were/are available. JVC introduced their own noise reduction, back in the 80's, hoping to rival Dolby Labs. However, that never transpired. Some cheaper decks used generic noise reductions. But such generics often amounted to simple filters which only muffled the sound.
Final thoughts:
I set up my Aiwa boombox on my entertainment center and sat in my usual listening position in our living room. This Aiwa boombox sounds very good. Bass is definitely apparent in all but the lowest octave range. The sound is full and clean. I keep the bass at '0'. Treble is set at +1. X-Bass is OFF. The result is a very well-balanced sonic reproduction. Very nice. Non-fatiguing. No sibilance. I measured an overall frequency response of around 45 Hz to 20 Khz within +/- 10 dB, which is the generally accepted standard for a flat in-room speaker performance.
Kudos to Aiwa and Leotech!!!
Highly Recommended.
Transistorized
Very nice detailed review. I just got mine today. Still giving it the shake down test but so far, I like it.
Did you have any issues with some of your case screws being stripped? Three of mine were when I took mine apart.
goodman
Thanks for this detailed review. We already have a topic dedicated to this AIWA.
And here we are comment all available versions of this boombox:
If the moderators consider it necessary, they can move your review to the topic about AIWA:
Reactions: BoomBoxStash
BoomBoxStash
No. In fact, all screw were very tight. I opened the case 3 times. All screws seemed to go back noce and tight.
Is it possible you were sent a unit previously sold and tampered with?
Transistorized
I thought about that. I looked it over really well. My purchase was for new on Amazon. One of the first things I did was look at the pinch roller because you can always tell if a cassette has been played in it. Looked fine. All protective tape was still on the unit amd zero finger prints.
Not sure. It's definitely used now though..lol.
BoomBoxStash
It probably is new. You know, we're talking screws into plastic. It happens.
I like this boombox. I wrote another review on it, with just a basic overlay, pointing out what stood out to me. Most people don't really care about specifications. I submitted this review for those interested in tech and performance, or who, like me, recall the 80's, when any half-way decent manufacturer provided pages of specs detailing their products performance characteristics. Those were the good 'ole days lol.
It seems very well made and thought out, for what it is.
If Leotech or Aiwa reads my reviews, I'd like them to consider any the following:
1) Add a tape counter.
2) Add full auto stop (tape mode).
3) Add line-out jacks in rear (from any internal source).
4) Make tape deck door removable.
5) Offer a rechargeable battey option. Either built-in, or an accessory rechargeable battery pack which would fit in the battery compartment.
6) Maybe a vinyl protective custom cover, to allow outdoor use while simultaneously keeping the unit clean and pristine.
7) A REAL SPECIFICATIONS PAGE!!!! Detailing performance characteristics of each section. Possibly, some specs could be available from a related service manual?
Just some thoughts.
Reactions: Transistorized
BoomBoxStash
Speakers:
Amplifier:
I measured:
CD Player:
Tape Deck:
Final thoughts:
Highly Recommended.
As an addendum to my above evaluation:
I neglected to comment on the REW graph I attached to my initial review.
The REW graph indicates the following:
The top red line represents the amplifier section's performance at the 'FTC' styled measurement of 8 watts continuous sine wave into 4 ohms from 65 Hz to 20 Khz at less than 0.35% THD. (The graph does show the full performance from 20 Hz to 20 Khz).
What you can plainly see, is the amp's output, above 100 Hz is very flat, rivaling that of home component amps/receivers. That is pretty impressive. I have measured some 'retro' styled boomboxes which exhibited terrible response curves which were anything but flat, with response curves more resembling the Coneheads (remember that movie?), than a flat amp graph.
The middle white line indicates the THD level throughout the 20 Hz to 20 Khz range. It, too, is pretty flat, again, attesting to this boombox's performance. Only in the deepest bass range, does the THD rise, as is typical with most amps, including home component quality units.
As an example, my Yamaha receiver measured a very low 0.019% THD at 1 Khz, at rated output. However, its THD rose to just under 0.08% in the lower bass range. An increase of a factor of 4. Subsequently, this Aiwa's amp section measured about 0.148% THD at my stated output at 1 Khz. The THD rises to approx 0.8 to just under 1% in the lowest bass range, between 20 Hz and 60 Hz. That's an increase of a factor of 4-5. So, this amp acts and performs very similarly to higher end 'hifi' home components.
The bottom red line indicates the noise floor. It, like the 2 curves above it, is also pretty flat, again attesting to this amp's better performance characteristics, for a retro-styled boombox.
Transistorized
One of the things I plan to test is how long this radio will run on batteries. The top of the radio gets warm under moderate usage so I expect it to drain batteries like there is no tomorrow.
goodman
Congratulations again on these excellent specifications.
Regarding the 7 points, here is my opinion:
1 - adding a counter is an additional complication,
whether mechanical or electronic (to be shown on the display).
At the same time, it is a function that is almost never used. I personally have used it very little.
2 - full auto stop is possible, but with a different type of mechanism.
I usually wait for the end of the tape and prefer to stop it myself.
3 - nowadays the headphone jack is used, at medium sound settings.
4 - tape deck door removable is possible, but I don't know why they didn't do it.
5 - rechargeable battery + remote control in this version:
6 - vinyl protective custom cover is a possible extra.
7 - the user manuals are different for different versions, but they have very little information.
Is that with both channels driven?
Any way to get how much it will put out at 10% THD? I know that's an intolerable amount of distortion, but it's what boombox manufacturers usually use in their specs.
BoomBoxStash
ItOne of the things I plan to test is how long this radio will run on batteries. The top of the radio gets warm under moderate usage so I expect it to drain batteries like there is no tomorrow.
It might drain quickly. But, idk if the heat buildup is directly proportional to power usage. I've tried D-class amps which get pretty hot, despite all the hoopla about them being so efficient.
This amp is a class AB, fyi
BoomBoxStash
I measured 10.6 watts, one channel, 10.3% THD. Two channels may drop that output figure slightly, but I would not expect a big difference. I'd say this unit delivers a solid 10 watts per channel, 2 channels driven at 10% THD. And, that is the wattage claimed by some of the same models released in Europe, under different brand names. Hope that helps
Transistorized
I can certainly tell you this. It has sent me to bed with a bad case of tinnitus last two nights. It's dangerously loud if you get carried away and stand too close. It's not so much the lows, but those highs. I have to say, they are on par with the M90. They are crisp.
Thank you! And it's an AB amp? Interesting, I thought all portables were class D these days
BoomBoxStash
I agree, the treble is very good. Clean, distinct. Not the typical shrill tweeters found in so many boomboxes.
BoomBoxStash
Yes, class AB. Not all boomboxes going with D-class. Personally, I prefer AB. In general, a smoother, warmer even output.
class-D, especially cheaper class-D amps which might be found in less expensive amps and in designs such as boomboxes can sometimes sound shrill, if not properly filtered.
The AB amp chip in this Aiwa has a very flat response curve above 100 Hz. Almost as flat as my Yamaha home receiver. To me, that's pretty impressive.
BoomBoxStash
Oh, and by the way, the power supply of this Aiwa is only 12V. I tried a couple under-$100 D amps which delivered more output. But, there's always a catch. One amp required 24V. Another, around 36-38V. That latter D chip's data sheet stated as much as 48V 10A was required to really reach that amp's full potential. The latter D amp, when supplied with a 36V PS, also got quite hot, which I thought they weren't supposed to do lol.
When I tried powering some of those D amps with a much lower 12V PS, they sounded weak and clipped very easily.
I'm not sold on D amps.
Interesting. I'm assuming the GPOs are class D. The Brooklyn takes 15V and the Manhattan takes 18V.
Btw, I actually don't think the Brooklyn sounds bad. It's just that the CD player vibrates with bass-heavy tracks. I tried adding more felt over the existing felt on the mechanism, but it only improved by a little. It's just too thin of a mechanism, so its moving parts rattle against each other.
BoomBoxStash
Both GPO's are Class-D. I cannot recall the chip in the Brooklyn. It is a single-channel chip, very small, without any heat sink (2 chips for 2 channels).
The Manhattan has a HT-317 chip, if I recall correctly. It is a Class-D bridged BTL. Some of the older Manhattans did not have a heat sink. Newer models did have a small heat sink.
I had the Brooklyn. I just couldn't make myself like the sound. Mids and highs were good. Bass was too hollow for me. And quite weak. The plastic shell is too flimsy. The rear is not sufficiently braced. As you said, the CD section vibrates and rattles. Nice speakers. But, not well tuned. It's too bad. The Brooklyn still looks the most like an old-school boombox. And had the most of all the old-school features, of any retro boombox.
The Manhattan is a night and day better. Much more power. The interior MDF sub-enclosures are well tuned. Balanced low and high ends. But, not as good sounding as this new Aiwa. The GPO Manahattan delivers more power output. But, the amp is no-where near as flat as the Aiwa's amp. Treble is not as clean. And, frankly, it really isn't an 'old school boombox'. It's just a bluetooth speaker that 'looks' like an 80's boombox. I returned mine. I'm much happier with this Aiwa.
BoomBoxStash
Yeah. I messed with mine. I tried constructing more bracing. But then I noticed the rear of the cabinet, particularly the 'Royal' emblem vibrated. The top vibrates where the front and rear halves join.
I got so desperate, I was messing with the Brooklyn, one night, late, trying to improve the tuned plastic enclosures. I accidentally dropped a screwdriver on the mains board. I had forgotten to turn it off. I saw sparks. Threw the damn thing in the trash. I was so frustrated. I should have sent it back for a refund, instead of trying to improve its performance lol. My mistake. This electronic audio hobby can be addicting. Man, was I pissed at myself. What a dope I am.
I like this Aiwa. It performs well. Needs nothing that I want, anyway.
