Excellent information! I’m very thankful.That looks pretty worn out!
When you look from the side of the head at a glancing angle, you will see concave depression/s showing the wear pattern.
If you see that kind of depression it is worn out.
The existing wires on the deck is color coded, take pics and connect like that on the new head. You might have to align the head turning the screw back and forth on the spring loaded side of my deck mounting screw. Don't use magnetized screw drivers when you are aligning it. It is advisable to demagnetize the head also.
Contact time with the soldering iron must ne just enough to connect the lead wires, prevent overheating of the leads.
Thank you! The radio is loud, working correctly as far as volume goes. It only needs the 2 antennas for best channel reception.If the radio is also quiet, have you tried moving the record bar a few times? That would be the easiest solution.
I sprayed it in all areas and moved it manually back and forth. No change in tape volume output though.If the radio is also quiet, have you tried moving the record bar a few times? That would be the easiest solution.
Thank you! I sprayed the record bar and moved it back and forth. No change in cassette volume output though. The whole circuit board is pretty grimy and dusty. Could it be all that dirt on the circuit board? I used the cleaner in the pick below.Try cleaning the record bar switch with Deoxit fader F5 clean and lube. Actually all switches must be cleaned.
I myself often enough tried many laborious things only to find out moving the record bar a few times was the solution. Sorry it didn't work here.Thank you! The radio is loud, working correctly as far as volume goes. It only needs the 2 antennas for best channel reception.
Looks about the same. Very helpful to have these pics! Thank you.I found some pics of my M-X824 cassette player I worked on last year.
I believe it's close or even identical to the 960.
Your cut blue & white wires might go to a switch mounted above the motor, I believe there are three switches in all.
They each get depressed when play, ff, Rew or rec are chosen.
Here's a good shot of the workings below the capstan flywheel.
Yeah, the record bar… Prior to cleaning, it was a bit stuck. I sprayed in all the holes and at both ends and moved it back and forth manually about 100 times. Then I repeated this process 2 other times. The bar moves well now. Although I have not tried to record anything yet.I myself often enough tried many laborious things only to find out moving the record bar a few times was the solution. Sorry it didn't work here.
The cleaner looks ok to me as it says it cleans and protects. The ones that say they 'remove oxidation' are the ones to be careful with as the can damage delicate surfaces and parts such as potis etc.
The cutting in and out of the left speaker could be a broken solder point on the back of the plug in the picture. Look on the other side of the pcb to see if one leg has become loose.
I still can't give you a solid lead to fixing the low volume on cassette playback though. Maybe check the plugs that go from the cassette deck into the pcb – or better all plugs –, pull them off and spray them with the contact cleaner. Also look for broken solder joints on the backside of the plugs. But honestly I don't believe that's the solution as both channels are quiet and it is unlikely they both fail from a oxidation. Still worth a try.
No worries. I like cleaning and the process of eliminating potential issues to narrow down the causes. I cleaned as many plugs as I could. No changes in the cassette volume output.The connectors, like the one you circled yellow in one picture. Or in the last picture the one with the black and white cable. Sorry for confusing you, I am not a native speaker, haha.
These are really low level repair tips I give you but it is best to try these out before you start changing capacitors etc.
I don't know what could cause low volume on cassette playback, I just try to eliminate simple causes.
Other more experienced forum members need to jump into this thread.
Thank you for asking. I didn’t need to do anything with the original blue and white wires since my aftermarket motor has a speed adjustment in the hole of the motor cover. It worked great with a small standard screwdriver. Besides the speakers cutting out due to the plug (I will do exactly as you said for the fix), the only thing left for this machine is the low volume during cassette playback. I turn up the volume completely and here a faint level of volume for the cassette. Volume works fine with radio and line-in/phono functions.Did you ever get the blue and white wires connected to something?
It looks like there are blue and white wires connected to the "speed control" + & - on the board.
I know you were having a problem with adjusting the motor speed, maybe those wires have something to do with it.
My m-x824 didn't have an adjustable motor (I believe it was original), probably the only box I've worked on that didn't and when I got it back together, the motor speed was dead on.
