So long story short I've got an Aiwa AD-M700 I'm trying to resurrect. Fortunately I have a parts deck which has come in handy. Deck has been cleaned, lubricated and new belts have been installed. Also replaced the idler tire, RW/FF tire and take up reel tire. Switches have all been cleaned with deoxit and I'm good there. Here's the issue that has me stumped...
When playing from source input the sound is crystal clear and the VU meters don't skip a beat. When playing a tape the left channel goes in and out and the VU meter on the left dies out with it. I happened to touch one of the wires coming off the tape head with the tip of my screwdriver at the board end and the sound came back! Then it got staticky and went out again. Touched that wire with the screwdriver again and voila! Comes back for a minute or two then dies out. Right away I assumed it was a bad connection there so I resoldered it. No change and it's still doing it.
I know the connection is sound so what did I do by touching that wire with the metal end of the screwdriver to make it work? Did I alter the resistance somehow? Does this point to a bad cap on that side? This issue is with the left channel only.
Any help or advice is most appreciated. Thanks!
