I’m playing a belt-driven turntable through my Sanyo m-x650k and am having various sound quality issues. At first, while in Stereo setting, the R channel didn’t work and was buzzing. I cleaned out the red and white ports from the back with contact cleaner and cotton swabs and used contact cleaner again on all knobs including bass, treble, balance, volume, as well as the switch for the mono/stereo/expand control. This resulted in both channels playing on Stereo setting, however the quality of sound seemed inconsistent. Sometimes the bass would leave completely, or the other channel might not work, or various other responses that are either difficult to describe or I forgotten about. Is this a matter of continuing to use contact spray and overtime will get a better sound? Or is this more than just the contacts? Not sure how to start diagnosing this issue. After attempting another cleaning, the R channel is not working in stereo again.
Other info:
- I have used another turntable on the line-in and had the same results.
- I have no issues with both channels in stereo using the cassette deck and no issues with Radio, also no issues with the bass, treble, balance and volume while using radio and cassette.
-buzzing in the R channel will increase or decrease with manual rotational movement of the red cable, and sound quality will worsen in the L channel with manual rotational movement of the white cable from the back of the radio at the line-in ports.
Any information is much appreciated.
