2nd update.sean 91 said:1st update:
iv'e cleaned the corrosion from the cassette heads last night and both decks now play and record in perfect sound quality.
the auxillary is still a bit touch and go. it works ok for 10 - 15 mins, then sound cuts out. But when i wiggle the function switch and turn the unit back on, it will work again. so now that i know which switch is causing the problem, i can pay it more attention. i'll see how that goes later
btw, would anyone know what year this dates from?? aso, am i right in thinking that the 575 were 32 watt? because this one is rated at 45
cheers
so i found that the function switch was the route of the problem behind only 1 speaker working. That problem i sorted, but it still remained when using auxillary, and some of the time the sound would cut out all together. the fault turned out to be another switch on the rear of the unit, circled below
the switch controlls phono/line in and it was very tempermental. it would of been a pain in the neck to access from the inside, because the intire stereo is attached to the rear section of the box with many screws in awkward places. so i just pushed the straw inside, and coated it the best i could with the switch cleaner. now the auxillary works perfect, though i shall be going easy on it for the next few days
now, everything is working. i will next be tackling the speakers, and trying to find some the right size to replace the originals (16cm/6 1/4")
and the year is 1982 aparently. its older than myself
Sean
