M70 & M90 with hardwired bluetooth module mod.
14,130
108
Naples, Italy
Since no one said it, DIBS on the oxadon
Next, I HAVE NEVER HEARD JOE'S VOICE! That's not you!!!! :lol:
With all the bluetooth I have had, only my Blue Ant Ear Bud connects every time reasonably quickly. All the rest have required finessing and have randomness in them.
Still really cool, Interested in the final product. If this works, I will follow suit for sure!
10,669
168
40
WI
I didn't test the range of the BT, i will do that after the install is complete.
The M70 has been opened before but the chassis has never been removed. Both black handle tensioners are missing, which is strange.....
It isn't broken, just really dirty. Breaking it down to clean should be done anyway. So far so good. I will get the bits cleaned up quick and put it back together with another video showing the points to install, how I wired my 12v, and what kind of working range it will have.
Next vid I will use my real voice, that was my 'kid tone' for when I talk to my daughter lol.
trippy1313
2,112
96
Seattle-Tacoma, WA
Opened before??? Apparently it was used for smuggling drugs!!!
Anyways, with connecting it, have you noticed it being any different if you wait say, 30 seconds after powering up the module?
10,669
168
40
WI
I left the module powered up and linked via Bluetooth playing through my 5350 for about 2 hours. It never cut out. Signal was good and strong, no issues that I could tell. Just the occasional connecting problem when first powered up.
jimmyjimmy19702010
3,578
26
Sunny Brisbane, Australia
It looks like the sort of setup I'm after for my DIY boxes. Currently I'm using a $7 USB style dongle. It works fine but an internal setup is definately preferable although it would end up costing me around $60 each in AUDs!! The thing is this $7 Bluetooth dongle automatically syncs with my IPhone every time in a couple of seconds.
It would be great if you could pin point the cause of your occasional sync issues.
10,669
168
40
WI
Some progress!
Swapped out the RCA jack panel that was broken. Also changed out the plug port by the power supply.
To make this short and sweet, I wanted a designated button to turn the BT module on or off whenever I wanted but with using an existing switch or switch hole. I was going to modify the beat-mode switch that no one ever uses, but I wasn't digging that.
I was checking out the 'record mute' hold down button and saw that this is the best spot! I would need a 1 click on/1 click off type switch. My parts box lasonic 922 saves the day again! Metal mounting bar and switch fit perfect where the original rec mute button was.
Just unplug the rec mute board and take it out. No permanent modification needed! I just need to run my 12v+ supply and BT+ to the switch and run my black- from the BT to the ground on the main board.
Thats it for tonight LOL.
10,669
168
40
WI
I didn't narrow down my 12v regulated supply just yet. I did test some spots that were seeing up to about 20v. It will probably be the regulated 12v for the cassette deck.
