jimmyjimmy19702010 said:High sensitivity is the key, not the ohms rating. All of the above brands mentioned (except for Sony) only produce 8 ohm bookshelf speakers - you will find most also boast sensitivity ratings below 90dB. 8 ohm resistance is the standard for HiFi speakers. Most amps won't run 4 ohm speakers without increasing the risk of damage. Some of the high end models with their huge power supplies and heatsinks will run 4 ohm speakers no problem, however, your Pioneer amp isn't one of them.
image.png![]()
But you ask, why does it have a switch on the back for 4 ohm speakers if it can't run them safely? Well the answer is that by switching your amp into 4 ohm mode, you are actually hobbling the amps' output power to reduce excessive strain on the amp when you connect low resistance speakers.
So 8 ohm, high sensitivity speakers are the way to go.
Happy speaker hunting.
James....![]()
Thanks, Chaps - I think I'm still in pre head spinning mode although I think I can see some testing times ahead judging by the depth of info (for MEReli said:There's a switch? I don't see a switch. It just says that if you're using A + B speakers, they should be 8 ohms or more, but if you're only using 2 speakers, you can use 4 ohms or more.
Here's a pic of the Amp's Speaker Selection switch which probably fits in with what you're both saying and thanks for the explanations, I understood these.
I've tried to sort the 'So Far' list into an order of importance so I've given the Sensitivity rating the highest priority. A Sensitivity rating is a new thing to me, I'd never heard of such a thing, Nope. No Siree, not me.
So, now this is my guide:
Sensitivity rating: At least 90
4/6/8 ohms, lowest possible best, Sensitivity (90 min) availability may influence ohms option?
Brands: Polk, Klipsch, Sony, Boston Acoustics, etc..(established brands)
No foam surrounds on woofer.
Bookshelf style, around 11-12" tall is a likely size.
Woofer Size: 5" (+/-1") woofer is usual for the physical speaker size.
Rear facing bass ports for increased Bass effect.
2-Way
$200 (or less?), a good brand & new may cost more.
