It used to be ACE, but then a midwest chain bought them out: Bomgaars.. But still the same stuff!redbenjoe said:ace ?
or which hardware store
The screws were 8 x something, 3 long maybe.. 8 x 3 or 8 x 2
I did the same thing with mine. It was missing 3 screws.On a related note, I went to the hardware store the other day and found all the screws needed for the back casing! They are threaded all the way down compared to half-threaded like the originals..
Yes, on my Korean Conion I stripped the blue off the tuner backplate then polished the bare aluminum for a chrome look..numbers still light up in white!superlew said:I did the same thing with mine. It was missing 3 screws.
I think the Pearl White will look awesome. Do you plan on going lighter with the tuner dial backing?
Can't wait to see how this goes.
WHAT?!? Is there a pic of this?JustCruisin said:Yes, on my Korean Conion I stripped the blue off the tuner backplate then polished the bare aluminum for a chrome look..numbers still light up in white!superlew said:I did the same thing with mine. It was missing 3 screws.
