Being as I love looking at a box as much as listening to it, most of my time and effort would go into the exterior. My dream box would be one that from a distance could convince any of us that it was a long lost prototype the likes of an 880, RX7000, C-100F, M90, S90, M-X920, etc. that surfaced after being mothballed back in the early '80s because of bad planning, went over budget, and couldn't couldn't get the time to cost-reduce it. Get closer to it and you'll see the labeling is for more modern uses and the tape door opens to access modern controls and so on.jimmyjimmy19702010 said:This new thread is really an ideas fest.
I think all project builders would like their creations to look just like a vintage box - that would be the ultimate!! Imagine an M90 MK II?!?caution said:Being as I love looking at a box as much as listening to it, most of my time and effort would go into the exterior. My dream box would be one that from a distance could convince any of us that it was a long lost prototype the likes of an 880, RX7000, C-100F, M90, S90, M-X920, etc. that surfaced after being mothballed back in the early '80s because of bad planning, went over budget, and couldn't couldn't get the time to cost-reduce it. Get closer to it and you'll see the labeling is for more modern uses and the tape door opens to access modern controls and so on.
It looks clean, factory-manufactured, the design is busy but balanced, and has classic era styling -- any combination of chrome, brushed metal, plexiglass, black grilles, chrome dust caps, plastic case, lots of vents, ridges, angles, detailed labeling. The case would be plastic and would have to be 3D printed or injection molded I guess, I'm not very knowledgeable on what's available in the maker space there nowadays, but something might be possible. I've even seen some 3D models out there of people just playing around drawing replicas of classic boxes, so spending a bit more time getting it to be something buildable might be possible, who knows. Just dreaming big here
I can design and manufacture all the trim and labeling, but would have to design a lot of smaller pieces and figure out a way to modify off-the-shelf components to work for what I'm trying to do, but with a little magic here and there, maybe someday.
The other idea is to simply recycle trim pieces from vintage boxes, like Hardmen does. Grills and knobs especially.caution said:I like. Makes the build simpler, and they'll be stackable.
A lot would have to be decided on features and layout, and I'll have to teach myself a 3D design tool, but doable.
Yes, from modern ones.Reli said:Love the LED meter on the first one. Is it straight from a Lasonic?
The second one could see finished in that pic below (right n the custom one with four woofers, that I made as well).Barb Bush said:Those are amazing. I like the EQ and LEDs on the first video. Awesome.
Kind of hard to see the 2nd one, but the chrome rings around the speakers remind me of my Sanyo M9990 I had back in the day.
On Red and Denim, is that a horn loaded box? Can't really tell, but it probably hits pretty good if it is.
Have any of you run these against the new modern boomboxes for comparison [diamondboxx, aiwa]?
Brilliant! You guys are definitely creative when it comes to these beauties.hardmen said:The second one could see finished in that pic below (right n the custom one with four woofers, that I made as well).Those are amazing. I like the EQ and LEDs on the first video. Awesome.
The Red and Denim have vintage tweeters and could cover mid frequencies, used in PA speakers, made by a Brazilian brand name Selenium.
I have the Aiwa Exos 9 and on my tests, they go more louder, but Aiwa sounds better (no distortion) in max volume (awesome project) and with more thumping bass.
The ONLY one of mine DIY that follow Aiwa on almost same no distortion, it's the Pausonic.
Cheers.
Running those 12 inch drivers in 'free air' will cause the cones to move excessively. If you tested them in a sealed or ported cabinet of a suitable size, they should sound really strong.hardmen said:Yes, from modern ones.Love the LED meter on the first one. Is it straight from a Lasonic?
That pic below show a Gig that I working on.
12" woofers (fail on tests, couldn't handle bass, because they are for midrange frequencies),
3" tweeters and TDA7492 Amp.
That gig are mounted on a open baffle scheme, just for tests...
I will make a video.
Cheers.
Running those 12 inch drivers in 'free air' will cause the cones to move excessively. If you tested them in a sealed or ported cabinet of a suitable size, they should sound really strong.jimmyjimmy19702010 said:Yes, from modern ones.Love the LED meter on the first one. Is it straight from a Lasonic?
Cheers.
You're right Floyd. If we were to scan an existing box front panel, any changes could be made to make it look unique - like a 'future' model developed back in the day that was never released due to the decline era kicking in leaving it high and dry.JVC Floyd said:Whatever is eventually built I just hope its not a carbon copy of some other box, now combining the best features of some of the best looking boxes into a single design is the way to go.
Whatever happens I think it should be designed from the outside in ,meaning make it attractive then make it function, its harder that way I know but wtf can you do.
