Belt Sizes - Post known belt sizes for your boxes here!
10,900
130
I tried on a Win 3.11 and a Win 95 to run the software on the site to no avail.
However, on looking at all the files the one with a LOT of belt references with exact codes of ones needed in it is this PDF which is 4.1mb:-
Yikes!!!!! Did someone say belts????
So awesome find jaetee thanks a lot..
I just found out after ordering some belts for a bunch of my bbx's that some of the sizes are wrong :sad: I had ordered belts for two of my sounddesign boxes and the sizes were way off :sad: Some are good sizes though but if you can measure its probably better :thumbsup:Hey Bill, are you sure you were in the cassette player section? They also list VCRs, car stereos, CD players, etc. It's easy to get lost in there.
91
Yep ;-) I double checked after I got them and tried to put them in. The one belt said 5.2 and it is around 8-9 :sad: I did order extra and was able to get it working :w00t:
Ghettoboom767
4,307
56
Hi bill,are the sizes for the GF-9191 correct? Assuming you
Used the 9090 belts.
Let me know as I want new belts for my 9191.
Thanks-Jeff. :-)
91
Thanks-Jeff. :-)
Yep :thumbsup:
Sazeus
471
Melbourne Australia
What about the cartridge tracking belt for the VZ 2000? Anyone know what size that is? Or do I need 2?
Thanks, don't want to open it up til I get em.
Sean
10,900
130
Sean
Welcome aboard, Sean. Your best bet for all things VZ related is to go here:
viewforum.php?f=49
dooleywomack
MD, USA
I am brand new here, I picked up a Sanyo M9923 for $2 and am trying to fix it up.
Everything works great except the cassette belts of course, I have never replaced these before and am frankly not a very "handy" person, can anyone point me to the right sizes? Thanks!
91
My service manual says the belt part number is 4H 358 30223, now how do I convert that to ordering info so I know which belt to buy??
Most likely you can't and you need to measure old belt ;-)
91
Ok, thanks.. It looks to be a flat belt, I'll have to measure it once I get the unit.. :-)
What unit is it? Did you check the Rusiland PRB belts list?
nikonfoo
393
17
57
Need belt sizes for Sharp GF-6060
checked the PRB belts list but only lists 2 belts
FRX9.7
SCX8.4
I think there are 3 belts maybe they have left out the counter belt
anyone know I think the deck is also the same as the Sharp GF 5656
edit the more i look i think they have left out the shorter one on the wheel under the Capstan
and im thinking its a SCX5.1
can anyone confirm
:bow:
nikonfoo
393
17
57
ok no answer :sad:
so I hope this helps someone looking for the same belts
i tried to work it out with a similar deck
I have sent these belts to a friend and if all works
and will update this works out
Its a very nice chrome sharp and one day would like to get one too
so the data would be usfull
crazygamer
440
26
Estonia, Tallinn
nikonfoo said:
ok no answer :sad:
I have the same BBx, sadly i don´t remember the measurements, i usually measure them with my own bare eyes, so far has worked good, sometimes small adjustment needed but works out. As i remember right, GF-6060 runs on 3 belts, 1 on the back, flat belt and one top square belt and counter belt in the front. :yes:
