What kind of power supply cord do I need for RC-550?
68skyblue
8
Iowa
Hi. This is my first post ever. I bought a RC-550 and I need a power supply cord for it. It says "DC-12V". Here is a photo. Is this something I can find somewhere? Thanks if someone can help. It's working off of the eight D-Cells right now.
1,072
808
113
55
Maryland usa
there should be another plug-in location either on the back of the Boombox or on the side that you put a AC cord in , this will allow you to just use the cord to plug it in the wall mind you there's multiple voltages for these boomboxes depending on whether you live in North America or in Europe so you have to make sure that the voltage is set accordingly there should be a voltage selector on the back of the box. make sure you check the voltage before you plug it in.
1,072
808
113
55
Maryland usa
if you find a socket on it that says AC then that means you can plug it in with a simple cord. if you don't have a cord then post a picture of the socket the cord plugs into and take it from there.
1,072
808
113
55
Maryland usa
it's most likely already set to the right voltage you just have to find the right AC cord.
68skyblue
8
Iowa
Thank you. Here is a photo of the AC socket. I don't have a cord. By the way there is a recessed hole next to the power supply sockets that reads "120V".
1,298
292
Melb AU
That's not standard the pins maybe two close together. It's actually a Rectangular plug similar to a shaver.
5,763
276
#5 is what I selected and it will fit most of our boxes except Sony CFS 99 etc.
Those V shaped cuts on either side ( the gap on the top is close) should lift the battery cut off switch also.
I had luck with those types for many boomboxes.
1,298
292
Melb AU
Thank you. Ordered. This won't be my only question, ha ha. Appreciate this resource.
Can you measure the distance between the two pins on your box? These old boxes have pins closer together and not compatible with new cables.
1,298
292
Melb AU
New ones are 8.5mm if you try to use you will be bending the pins in the box.
This is the correct one although very hard to find. The pins are 7mm apart old shavers have this plug as well. jvc plug.JPG
68skyblue
8
Iowa
Received the cord that I had ordered and the measurement confirms the slight differences discussed above. I warmed the radio a bit near a space heater and then inserted a needle-nosed pliers in between the pins to widen them a little. I inserted the cord with no problem and the radio sounds fine (batteries out). So I appreciate both responses; the practical one and the technically correct one. I'll post another question soon....I need to open it up.
5,763
276
That 0.75 mm clearance on either side of the holes make no difference at all to fit in. The female pins will easily wiggle/jiggle and accommodate in the plastic holder of the plug. :-D
5,763
276
Why would you this is a so called Grail?
Because nothing will happen to the pins at all!
There is good tolerance.
It is not special like the pins of Sony CFS 99.
Most of all JVC AC cords for M90, M70 etc. will suit RC550.
JVC RC550 cord is not anything very special!
There is no need for overengineering!
1,072
808
113
55
Maryland usa
that's why I like a boom box with built-in cord. seems to me a removable cord is the dumbest idea ever. if a cheap box can have a built-in cord why can't an expensive one.
