I found a motor from Audio-Technica's own spares outlet when mine needed to be replaced. I then repaired the outgoing motor as the problem was nothing more than the usual weak brush holders. I don't hold out much hope but will look for that motor just in case. Meanwhile, have you considered repairing yours? Once you attend to the peened end of the motor tube, which can be a sod to shift (Dremel needed but go carefully and don't use a split new disc), the springs and brushes themselves are easy enough to replace though as AT only carry complete units, you'll want to cut down brushes from something else and use Bic springs, again cut down, to replace the originals.
