VZ-2000 Record deck speed issues.
marcusalcock
Hi there everyone.
My VZ has new belts all over but after a short while playing vinyl the speed changes and wows slightly. I've tried cleaning the belt and platter but it seems like it's an electronic fault to me. Weirdly it doen't seem to have a problem at 45rpm but that might be because the disc isn't playing for long enough for the fault to occur.
Anyone else had this problem?
Thanks
Marcus
Funkateer38
Hello
The simplest way to check the position of the record size selector.
Then clean the LEDs behind it
Kind regards
stevenrob
Hello, I take the opportunity to ask a question. On my VZ2000 the reading speed has slowed down but only for the B side. Do you have an idea? Thank you
