Hey folks,
I've been working on my first VZ -2000 and have come across a bit of a problem. The balance fader has dropped its brush (see attached photo). My initial plan was to de-solder the fader, repair it and re-solder it to the board. Unfortunately, I'm not having much luck on that front. Neither wick, nor solder sucker seems to be doing a decent job and I'm afraid I'll start lifting pads if I keep at it. I'm using a good quality iron with a well tinned tip (though it is conical). I was able to bend up the end of the fader to extract the brush and I read somewhere about someone reattaching it that way, but it doesn't seem very viable to me, there's not a lot of room to work and I can't see how I could jam the brush under the fader and affix it. This led me to wonder if I could just solder a bridge on the underside to essentially negate the fader. I'm not worried about resale value, this is just for my use and I don't have any need to tweak volume from one side to the other. Does anyone have any thoughts/experience on this front? I've attached pics of the underside where you can see my piss poor attempts at de-soldering (VR302). If anyone has any insights or could walk me through what pins to solder a jumper wire to I'd be forever grateful. I've already replaced all the belts and cleaned everything up, this is the last hurdle (I hope) before bringing this back to life.
Cheers and thanks.
Cheers and thanks.
