top tip for tyre replacement!!
saxonman
Over the last six months i have been trying out O rings for RW/FF tyres and have been quite successful !! as long as the tyre is easy to get to and you don't mind trying different sizes it works !! I have only one box which i have done and use alot and that is nearly 4 months ago and have had no trouble so far I'll keep you informed as how they go !!! has anyone tried this method ??
milosancho
I've also reaplace a couple of mine with o-rings and they are still working. I came across some replacement scuba gear small parts and it turns out scuba gear uses small o-rings that needs replacing and they are a great size for the boxes that I've worked on. Type in the Ebay search "Scuba O Rings" and you'll see what I mean. You can get a large assortment for cheap.
