trippy1313 said:
Okay, I could use 4 more D cells. The baby swing and rocker uses 5.
^^^I know right? It might be my OCD kicking in but doesn't it annoy you when items take 3 AA or 5 D's etc..?
FYI. I wrote the company for information on the charger. I asked if the charger had a temperature sensor since a few AA cells I had (that I knew were on their last leg) reached 126 deg F in the charger. Their response is below but first...
A word of caution on this charger. If charging in Soft mode (1A) if the power blips at all, it will default to Rapid charge (2A). Normally that wouldn't be an issue if you are charging a depleted high capacity battery rated at 2,000mAh or higher however, if the power blip occurs towards the end of the charge or with a lower capacity battery charging (less than 1,000mAh), well...you might come home to find it has fizzled out, leaked, exploded and/or has reduced life afterwards. At that point, you would have to rely on -Delta V to catch when charged (temperature is not monitored). They warn against rapid charge in the manual with batteries that are 700mAh or below yet their charger defaults to rapid
Rarely should this be an issue since most modern AA NiMH are at least 1,800mAh or higher but nonetheless is still a possibility with older batteries. Especially if you are charging AAA's rated at 700 or lower. I also can't imagine a higher capacity battery that's 90% charged with less than 1,000mAh charging storage left...would like a rapid charge to finish it's top off
This is a great charger no doubt. The Cadillac of chargers however, every device has it's flaws and the Powerex Maha is no exception. The work around is a UPS (which I have just in case).
Here is their response on safety related to temperature and impedance:
Hello,
Thank you for contacting Powerex / Maha Energy.
The MH-C808M does sense for impedance but not temperature. The charger will detect if the battery is not suitable for charging based on impedance.
Thanks!
Powerex CustomerCare
Powerex by Maha Energy
customercare@mahaenergy.com | 1 (800) 376-9992 | www.mahaenergy.com
