Tape deck key replacement? Seeking advice!
Parkville
Got a complete set of tape deck keys for the conion! :yes: How hard is it to replace them? :huh:
That's great finding a set of nice keys. While I was cleaning and replacing belts I noticed keys would not come out so easily so I left them alone and just cleaned them while being on. I would use extra caution when putting new ones on as the plastic is 30 years old and can be brittle ;-) Good luck :thumbsup:
Parkville
yes! The same here if it is not broken don't fix it. :no: But the problem is, I have no keys at all. Just missing all the keys could see all the bases. I might just remove the keys from the whole assembly. Thanks for the advice! :-D
SINISTER
Banned
the "C" part should clip on and off semi easy lasonics are full circles and the rod needs to be taken out but these are easy :sin:
