Just got a mitsuba box in and the tape deck doesnt seem to work correctly. When I press play it immediately stops as though the autostop function is kicking it off.
Any ideas?
Sounds like something is preventing one or more gears from activating. It could be a missing belt. If it's logic controlled, you might have to get some real help.
That is correct. I knew the tape deck didnt work when I got it though. All the ad said was "tape doesnt work, needs something" and I was hoping it just had bad belts. That's why i got it on the cheap.
Worked on many kabooms (all boxes really, just kaboom comes to mind) and that finicky deck did the same thing on numerous occasions because of a minor belt stretch..
