Hi All,
I was wondering if anyone could help me with a diagram for the correct belt routing for the lower deck (Tape 1) on a Conion C-100F. I just rebelted mine with the recommended belts, but upon testing it, it's obvious that I did something wrong. Here is what is happening:
- Deck plays cassette correctly, but it spits the tape out of the bottom and I have to manually coil it back up correctly
- The right side spindle (the one that is linked via belt to the counter) is turning clockwise (I believe it should be turning counter-clockwise on this deck)
- When tape is playing, the counter is also counting backwards instead of forwards
I am pretty sure that based on the above, one of the belts is routed correctly, but the other is not. I am pretty new to this stuff and the belt routing is a bit confusing for me (the original belts were totally disintegrated so I couldn't just look at the old belts to see how to route the new ones.
I triple checked all of the wiring connections and am certain they are all connected properly.
I have searched online and can only seem to find how to route the belt on the upper deck.
Any help that anyone can provide would be greatly appreciated.
Thanks!
Thanks!
