Hi guys, hope your weekend is going well!
I'm in the middle of restoring my c100f at the moment and have a strange issue with deck 2, I've re-belted it, lubricated the moving parts, ha d a play around with it while out to make sure everything was moving smoothly and then put it back in, I popped in a cassette and it started playing fine, so far so good, but then when I pressed the prog button to change direction the deck just stopped playing, then no matter what I did it seemed to just not work, also when I tried to rew or ff it doesn't engage the buttons just spring back out.
I took it apart again and found that the mechanism that moves the selector switch was stuck part way through its movement, I wound the motor spindle with my finger and it moved the mechanism the full way, when i tried playing a tape again it worked, but it happens again when I try to press the prog button, has anyone else encountered this?
