I can write a lot about static electricity safety because I worked for largest chemical industries that did lots of manufacturing. One site was closed because of a fatality from static electricity. Proper grounding and bonding rules are very important.
I might have transferred flammable solvents so many times without proper grounding but I should say I was very lucky then. This employee was transferring toluene from a plastic bucket to another container when it all went in flames.
I think the carpet in Joe's boomroom can cause lots of static electricity issues. You shoudl wear cotton socks or a leather shoe when you are in there. This will dessipate lots of charge bulit in your body by walking on it.
The carpet in your boom room is one of the main causes for building up charge on your body and if you wear rubber soled shoes that will hold the charge without dissipating it. You have a lot of insulators in your home, like the rubber soles of your shoes and that wool carpet in the living room. When you walk on that wool carpet, your body then builds up a charge it can't get rid of through the insulating soles of your shoes. Then, when you touch that metal doorknob... you know what happens. Dry air is also an insulator, so static electricity is even more common during the dry winter months.P
One of the easiest ways to avoid static shock is to pay attention to what you're wearing and what kind of fabrics make up the furniture in your house. For example, rubber-soled shoes are great insulators, and will build up a lot of static in your body when combined with a wool or nylon carpet. Instead, try walking around in leather soled shoes, or cotton socks instead of wool socks. Leather soled shoes are also great for grocery shopping, since shopping carts can often cause lots of static electricity.
Similarly, wool sweaters are common offenders, especially in the dry winter (when you usually wear them). If you sit in a chair made out of the right fabric, you'll build up quite a bit of static. Again, cotton is going to be much more friendly, so try wearing cotton clothes when you want to avoid nasty shocks. Certain furniture covers or antistatic sprays can help alleviate this problem, too.P
You may have also noticed that often, when you get out of your car, you get a shock when you touch the door. You might have even heard that touching the door frame as you get out of the car can help, and that's true. Make sure you start holding the metal frame before you get out of the car, and you keep touching it until you're out of the seat completely. If you forget to do this, you can also touch the car door with your keys. Since the electricity will discharge through them, you won't feel a shock.
The tips above will work when you're out and about, but when you're in your own home, there are a few other things that ensure you can wear those rubber-soled shoes and wool sweaters when you want to. A humidifier can make the air a bit less dry, and thus lower the possibility of you getting shocks at home. Generally, you want to keep it above 30% relative humidity, though 40% or 50% would be even better.
