Speaker replacement options?
Jboulukos
What are the options for boombox speaker replacement? I’m all for vintage sound but I have a tiny tweeter that is ripped and the woofers lack bass. I recently watched a video on someone replacing their Sanyo boombox speakers with a brand called Visaton and I found them on amazon. The person had an issue with fitment though and had to order a smaller size. Anyone want to add their 2 cents with their experience with changing out the speakers? How do I measure the size in order for the screw holes to match the space available? I have a low budget build so I’m not trying to spend a bunch. Just want some decent clean sound. I’m going to attach a pic of the woofer and tweeter speaker specs. D29313D9-E997-4807-92C1-236B38158CF1.jpeg7D49D655-596A-48DB-956A-A15298BC8F27.jpeg
Most important thing is to measure the frame diameter, as well as the total depth. Also search for 4 Ohm speakers since those are plentiful and are a close match with your 3.2 Ohm.
Reactions: Jboulukos
