Sound 4010 hiding under nicotine
mmcodomino
So this is a flea find I have regretted buying quite a while now. I saw it under a table, it was big enough to look like it was good so I took it back then. It was covered in yellow nicotine and just very very ugly and all sticky. :-/
At home, I plugged it in and.....nothing :'-(
The unit was completely dead. I was discouraged. I really expected lots of static and a not working tape deck but this was the first guy to quit on me completely :sad:
So it sat there for a while and then I thought of the possibility that the trafo could be broken inside so I had a go with batteries in it.
BAM! :-D It was working on batteries, that is when I got happy with it. It saw it as a small challenge to get this sucka back to life.
So yesterday I had time and I took it apart. It was a lucky set up so I could get the front seperated pretty quickly and dunk it in soap water.
And I had to scrub it for so very long until some silver showed eventually. I could not believe it. It had an aluminum front plate :lol: .
So after an hour or two of scrubbing, I let the grills and front dry and went over to cleaning the knobs and the cassette door.
There was beautiful chrome under the nicotine! It looked like it was conserved over years under the dirt :lol:
So then when everything was cleaned, I still has the problem with the electronics in it. All switches had really bad contact and especially the volume knob was really bad. I fiddled with everything a lot and moved it around a lot and that seems to have fixed the worst issues on it! :thumbsup:
Don't get me wrong, it still needs lots of adjustment to get it playing correctly but FM stereo works and I played my iPod through DIN In :-D :-D :w00t: :thumbsup:
I had never thought it still had that much potential. now only some new belts and contact spray and it is all nice again :-D
I really discovered I had fun restoring this one and see the contrast to the nicotine filthy "thing" I bought back then. :-)
mmcodomino
MasterBlaster84 said:
Nice cleanup Max, sometimes filth is hiding some nice gems. :thumbsup:
These are good boxes and they can play very loud.
I just did a soundcheck and you are right :dunce:
This will be the perfect carrying box! :-D
mmcodomino
UPDATE I got the freaking tape working again, the first time I successfully rebelted a tape deck myself :-D :-D :-D :-D
It is FULLY WORKING again now :-D :-D :-D
I did the happiest dance ever when it played music without going waah waah :lol:
It is a normal rubber band in there now but it does a perfect job :yes:
monchito
this is the one i got that looks very simular its a macdonald brand still a very loud box and yes great for outside listening :yes: :yes: :yes: :yes: :yes: :thumbsup: :thumbsup: :thumbsup:
mmcodomino
monchito said:
[ Image ] this is the one i got that looks very simular its a macdonald brand still a very loud box and yes great for outside listening :yes: :yes: :yes: :yes: :yes: :thumbsup: :thumbsup: :thumbsup:
Definitely the same chassis :yes: Only the radio scale is different and so are the grills but I noticed I can take my grills off (which I did for cleaning them) and so it does have the same front :yes:
I just cranked up LL Cll J - My Radio on it and this thing rocks :thumbsup:
And i have to say it sounds twice as sweet because I fixed it all up myself :-) It's a good feeling.
When I think the fact that in the beginning it was very ugly and sticky and only played FM very very silent and the VU meters went berzerk once in a while just showing a full bar or nothing at all...it just stood too long. Now it is fine again without any contact cleaning inside :-D
by the way, I also re-did the little things behind the switches the protect the inside from dust. The old unes were ugly and broke apart since there were made from rubber, the news one are from black fabric stuff that looks very fancy on it :-)
Restoration is fun! :-D
Cleaning a filthy boombox is almost like going on an archeological dig. You never know what you will find. :-D Great job, Max!
PS - I'm waiting for the video of the happy dance. :lol:
:agree: :agree: awsome Job Max :thumbsup: :thumbsup: :cool:
mmcodomino
:lol: No video evidence here either LUCKILY :w00t:
I guess I just expected it to go waah waah but it played straight and I was really shocked by that :lol:
PS: I changed the belt again because the old rubber band got too loose and now I have one sitting in there pretty tight so I could adjust the motor back to the original speed...works fine since then! :thumbsup:
Are rubber bands okay for belts or should I get real belt sets that are made for that purpose? :huh:
Definitely get the real thing, Max. :yes: Rubber bands are good as a short-term, but lousy as any sort of long-term solution for a number of reasons. Among them are tension, size, and uniformity.
ViennaSound
Only original rulez! :agree:
Why did you tell it me not yesterday.
So i would have added you a belt to the radio i sent off yesterday. :blush:
will bring you 2 belt kits to the dessau meeting, ok? ;-)
