Hello!
I'm not sure if this is the right section to ask my question
So i found this sony fh 909r on my grandparents house and i'm surprise that its working though there are some minor issue
Memory scan and stereo/muting button are hard to function i need to press it many times for it to work and the back light of tuner and equalizer are not that bright. but the cassette deck it love it! and it works perfectly but sadly the handle is broken the other end of a plastic part and i dont know if epoxy will be strong enough to stick it together.
So my question is what's the wattage of the amplifer? and can i run 4 ohms speaker on it? cause i have 2 pairs of grundig mini box speaker 4 ohms 35w and the other pair 4 ohms 50w will it be alright if i plug it in to sony fh909? thanks!!
