Been on the lookout for a while for one of these or the 15R (the model from the year before i believe).
Big thanks goes out to Terry for spotting the ad on gumtree and to Shane Higgins for packing and sending to me as the seller wouldn't post.
It went from Perth (the very west of australia) to Brisbane (the very east). $50 for the system and $85 for the postage...but well worth it to me. The guy was about to take it to the tip too!!!
Came with the remote, and operation manual. It had a bit of a knock on the top of it but i mostly sorted that out now. LCD tuner light i need to replace as you can see...and the tape deck doesn't work. But apart from that it's mickey mouse. Oh the speaker surrounds were shot of course...but my local speaker repair guy had the square surrounds which were close as it gets to straight up fitting. I just needed to trim the outer edges down a fraction. Got the replacement surrounds as part of a repair kit that had instructions, adhesive and even a brush for application of the glue. Could not believe my luck. Put the new surrounds on the same night and waited until the next day for the glue to cure before cranking her up.
Well what can i say... the sound out of this small (but 14kg) unit blows me away!
The bass is ridiculous even without the AMFB (accurate motional feedback) button on.
Some photos below....i'm a sucker for cool lights and sprectrum analyzers.
Scotty
Scotty
