Hi Fellow Travellers,
I have a problem with an old Sony CF520 which was sitting for many years in slightly humid conditions. Testing shows: one stereo channel missing; sound comes from both speakers in mono and matrix stereo modes; line in has the same outcome (must mean output amp is working?) - some static/noise/on bad stereo channel at max vol .Headphone output mirrors speaker output. Radio and tape sections operate well. I attempted recording with no success - one meter responds, but not the other. . I have de-oxed all switches and pots and REC/PB slider switches - they had all been very noisy. I have checked for damaged traces/solder joints. I have a service manual (Hi Fi Eng) but the circuit layout is really hard for me to follow and relate to the schematic; I attempted some component testing and various caps and transistors tested good. I feel like the problem must be related to the function switch circuit (Mono/Stereo/Matrix stereo) as all output functions are equally affected. There is a 'block diagram in the service manual that give me some hope of narrowing down the problem, if I can decipher it - leaning toward the idea of faulty IC preamp chips? - but really have no idea how to marry the circuit diagram and the schematic; As a novice, I would appreciate help/advice from anyone who has experience with early Sonys. (c. 1979?) It is a solid unit and would love to resurrect. I am pretty good at detailed work and soldering, not so great at electronic diagnosis. Thanks in anticipation. GB
