so after pushing the button too aggressively the button had broken off the shaft inside
i was hoping i didnt have to find a salvage unit on the web and rip the button shaft out of it, especially when the unit is 24+ years old so, so a bit of DIY was undertaken
Trusty old mitre stick with activator
button quickly stuck back into place.....
a coat hanger......
so i cut out 4 little tabs with my cable snips.....
and glued them around the join for strength
To tidy it up a little......
and sorted.... its probably now a 1000 times stronger than it ever was
a coat hanger......
