I have been restoring 2 of these, one has side B tone arm completely missing and when they snatched it they even pulled out the tone arm wires. I was going to remove side A, but I can not get to it. It seems the chrome piece that attaches to the front has some mysterious way of being removed. I was going to measure it for a 3D printing . The schematic tear-down is unreadable. I was going to see if side A was exactly like side B tone arm, but I didn't want to break something. So, after a year of this insanity I did this: I put it all back together and left the phono out. I fit a 3/4" x 13.5" x 13.5" mdf piece of wood over the hole after I made a bracket to fit inside on the same protruding mounts where the phono went. Nothing fancy, but I did not use the mounts that you can see "daylight " thru. Those I ran wires thru to plug into the AUX INPUT, until I got the bluetooth receiver. The turntable has a rechargeable battery that charges up when you plug it in. I haven't ran it all the way down, yet, but I've got around three hours on it with it working flawlessly. The bluetooth receiver, also has a rechargeable battery that charges when it's plugged in. If you are a Nikola Tesla you could probably figure out the plugs from the phono and get juice to run the new turntable and the bluetooth receiver. I did not want to mess with anything to do with the VZ2000. In fact, if you have one of these that just has the speakers working without the tape deck, phono, etc. you can just plug a bluetooth receiver into the AUX INPUT and bring it to life from your phone or a bluetooth turntable that is in the house and use it as a 38 pound stereo pair of speakers. The board that the turntable is mounted on has added some weight to this, but I choose 3/4" MDF because I had it laying around. I painted it silver, but I butchered it up when I had to re-drill the final holes. One could even wrap the board with some contact paper or I was thinking of an old vinyl record cover when you easily remove the new turntable. The picture with it playing is not mounted correctly. The directions for hanging this on a wall is not clear. You do get a template for the mounting, it needs to be tweaked a bit. And remember to turn it off before you press the tone arm release or it will skip across the record. Not good. Keep the stylus guard on it until you got it adjusted. The turntable is this:
ION Audio Treble LP Stereo Turntable (Black)
B&H # IOIT95 MFR # TREBLE LP
There are cheap "suitcase" turntable out there, but this one runs vertical. So anyways, I hope this helps someone out there.
