Looking for some guidance here. Picked up a VZ-2000 and the only major issues so far that I have found are, the record player needs belts which doesnt look to be that big of a deal, and FM tuning issue which is where I need a little help. When you select the fm or fm stereo buttons there is only a hissing sound like you get on the AM side if you were not on a station. The sound does not change when turning the tuner from one side of the band to the other it remains constant. AM works fine, SW1 works fine, but when you select SW2 it actually tries to pick up the local FM stations. The sound is kinda garbled and staticy, but just barely enough to make out the song and when tuning the dial the stations are exactly where they should be on the FM tuner. I have taken the box apart and cleaned all of the tuner selector switches with contact cleaner, but it made absolutely no difference. ANY Ideas?
