I found a beat up Sharp QT-250 at a thrift store that was begging to be cleaned up. I opened it up and cleaned out the blanket of dust that coated every nook and cranny.
The tape deck works great. Only issue is when a tape is playing the left speaker is making a soft buzzing sound while the right sounds great.
When the radio is turned on, they both work with no issues. There is no speaker balance adjuster on this box. Any ideas on the problem? Easy fix? Thanks for any and all help.
