searching for colour match silver sharp 777Z please HELP
BoomBoomBlaster
as I said I wnat to paint the housing of my sharp gf 777z.
Just want to paint the top and the sides and the upper front (till the mics).
I have to match the exact silver to make it perfect. Do someone has a colour code that matches perfectly? Some experiences?
stormsven
Best way is to go to some paint selling shop which is making custom colors and they will make perfect shades. For 777 you must use high pressure airbrush too. The shiny particles in the paint needs to be kept separated from high flow air :yes: Spray or so will work bad :yes: . Member Bondar here paint em perfect that way. Cant see where he brushed it.
BoomBoomBlaster
thanks for the info, at the place where it will be painted they got pressure spray pistols working with air pressure. I will go to a car painter and mix the perfect colour, they can also try out at the bottom of the 777.
Ken
Mar-hyde. Dupli-color. Hell, Earl Scheib it... :yes:
Just don't spend an arm & a leg! :nonono:
There's a whole section of plastic paint at the auto parts store. I think I'll try Dupli-color HPV103 Vinyl Silver on my 767. Used it on a Sanyo mini once & it looked bitchin', if'n my memory serves...now where is it?
Pics to follow...
