Hi guys,
I 've just replaced the belts in my Sanyo M7790K and after i put everything together I have the following problem/issues:
The buttons for REW/FF and Play do not stay pressed when I press it for either rewind or FF or play a tape.
If I keep them pressed manually (finger force) the operations work but, as soon as i get my finger off the button it will release itself and operation will stop.
I have checked the AMSS solenoid as well as the Power leaf switch but cannot find a fault there. What else might be? Do you have any ideas?
I have the boombox open but I'm not sure where and what to look for.
I'm suspecting some part had moved out of its position while I was replacing the belts maybe? I don't think I lost any part from the cassette mechanism, i was extremely careful with the belt change.
