What us called the back plate of the deck.
With deck faced down, what you should be looking at is a metal plate which holds the flywheel in place. There are often screws in each sides to remove for the plate to be lifted.
Great! Thank you. I was able to change the 2 belts in there, the flat wide one coming from the motor and the other one as well. I changed the tape counting belt as well. A few things came of it….stop functions, fast forward and rewind both function, but I cannot get play to engage. I’ve tried to hold play and manually turn the flywheel. Also, the head mechanism will lift manually.
Upon inspection I noticed the following:
-play button return is missing one s This doesn’t seem to effect anything
-there seems to be a missing spring here at the area on the left above the record button. I believe it’s to engage or disengage the safety tab that goes into a full studio cassette to prevent accidental recording over.
-the head seems to be bent inward. Can you confirm the the head should be flat/90 degrees?
please let me know what I can do to get play working. FF and RW seem to work perfectly smooth. Thank you!
