I've been working on a pair of boomboxes and have run into this issue in both instances. I'll try to describe as concise as possible the issue in one to keep it simple and maybe I can replicate any possible solutions in the other.
Hitachi TRK-8080MKII
National (Panasonic) RX-5100 (japanese model) - this is the one I'll describe the issue in detail below...
Each channel has its own separate volume slider, and there's one general tone slider that affects both. I've sprayed out the REC/PB switch under the tape mech and worked it quite a bit. I've cleaned each volume slider with IPA and then flushed out with Deoxit. I've confirmed continuity on all wires heading from the board amp to the speakers.
The left channel is noticeably louder but also noisier, especially in the middle of the path of the volume slider. The right channel does not get as loud but is cleaner, less noisy, throughout the path of the fader. The tone control slider is only affecting the left channel and not the right. The left channel feels like it has the appropriate amount of volume, it's just noisy. The right channel feels soft overall and should definitely be getting a bit louder at the top.
This issue is present at the headphone output as well, not just the internal boombox speakers, of which there are 4 of (stereo, 2-way each channel). It applies to both the tape player and the radio. The sound is generally pretty good coming out of the speakers, aside from this issue. So it appears most functions are in good working order and I've cleaned and serviced as many areas as possible. I'm just stumped on this problem...
Any insight would be greatly appreciated. I'm well equipped to work on the unit and can follow some advice, just not sure where this problem could be originating from. Thanks
