Rising 20/20 sound problems
static2000g
Version:1.0 StartHTML:0000000167 EndHTML:0000000891 StartFragment:0000000457 EndFragment:0000000875
I'm not sure if this is an easy fix (and I feel like by now I should know how to trouble shoot for this. Anyways; My Rising 20/20 plays out of both speakers but the sound sounds shallow. There is no bass, it doesn't play loud really and overall just sounds like a cheap pair of headphones.
Thanks in advance
I know my 20/20 boxes really suffered from dirty switches/contacts. To properly spray these pots/switches, you need to open it up. It made mine sound like totally different blasters after I sprayed deox. No joke night and day difference. If you didn't try it, I say that is step #1.
static2000g
Lasonic TRC-920 said:
Also clean the headphone jack / switch :yes:
Either I'm the worst cleaner in Deoxit History or something else is wrong-lolol
Maybe there's an issue with the bass/treble circuit. I had to resolder a bass pot recently because it was intermittent, even though no cracks were visible in the solder joint.
