Replacement ariel for Sharp VZ2000E - SPecification
Uncle Les
Hi All
Can anyone give me the spec on the ariel for the VZ2000E. Mine is completely gone so I cant get length and diameter
Cheers
Les
Lasonic TRC-920 said:
This is a place I have looked at before, but have never made a purchase: http://www.kenselectronics.com/lists/amfm.htm
So are you getting SIM 5H then. I also seen these through another dealer.
I did't really look because I'm not ready to buy :-/
Chris I just ordered the RI-SIM 5H for my VZ 2000. I will let you know if it works. Thanks for info... I usually order from Russelind antennas in New York. They are the manufacturers of these antennas but shipping is more expensive.
Super Cool, I am interested to see how this goes. I was planning a big antenna order, maybe 6-7-8 at one time to cover everything I got AND to save on shipping. Please let us know if the quality is there. I'm also interested to know if they are metal tipped or plastic!
I know these are great quality because I've already gotten Russelind antennas. They are chrome tipped too :-)
