For the most part battery leaks is the biggest cause of the corrosion on the springs and compartmentStyleking said:Ok so as I get into collecting I'm noticing that boxes stored for a long period of time often have corrosion. Is there any quick way to remove or lessen the corrosion? Thanks![]()
I once got a box so badly corroded from battery acid that the tape deck inside was all rusty and corroded too skippy1969 said:Styleking.
What I have done in the past for corroded coils and contacts is.
Remove the coils and contacts from the unit if possible.
Take a small container and pour in some Naval Jelly and let the corroded parts sit in the jelly for a few hours while checking it often.
It usually removes the corrosion good enough to restore electrical contact and makes the parts usable again.![]()
Sure and good luck!Styleking said:skippy1969 said:Styleking.
Thanks Skippy. I'm going to have to get my hands dirty soon working on some of these things.
Old skewl said:IIRC vinegar will dissolve the acid assuming the coils and contacts are not too bad.
TW5 said:Them dollar store flashlights will give ya an endless supply of springs.![]()
