I want to remove the speakers, grille and components from the face of my Sanyo m-x650 for cleaning of the case. Everything looks straightforward except two small things(microphones?)to the side of the woofers on each side as well as a wire soldered to the grille on one side. My question is how to remove these items safely? Cut the wire leading to them then resolder it?
should I use a solder sucker to take the wire off the grille? Is there a way to do it without a solder sucker? Please advise. I will include a picture of it.
