LEDs are low current devices and typically require that they be run in series with a "dropping" resistor, which is basically a resistor who's value is carefully selected to pass a safe current level (based on specifications of the led, and the desired brightness level). The term "dropping" just means that it's purpose is to drop the current being passed. Over time, resistors can increase in value and this may cause drop in led intensity. Usually, they are a row of resistors that all look identical (10 leds will have 10 resistors). If you can locate the row of resistors, and they all look the same (same color bands), test them with a digital multimeter to see what they read. If you find one reading significantly higher in value than the others, it's probably bad. Replace it and the led brightness should all match again.
